How to change the spline line properties in partial view in 2 d ex: i want to set the partial line boundary like phantom , centreline or so on ?
Technically it is a broken edge so it should be the same as the solid part on the print. However, you have the option to turn it off so you can sketch your own spline or other curve to make up for it. Often I prefer the zig-zag edge and don't like the default version so I just sketch it.
Well, from the drafting standards I was used to the practice was the break should be a heavier lone than the object line. You used phantom to sow parts in a different position, or if you did a helf-section, or wanted to show a part transparent. Pro/E unfortunately does not give you some of those old school options. I simply leave it alone to save time.
