How to create a profile like attached image in pro/e sheetemetal
  • April 25, 2014
  • 3 replies
  • 3756 views
    Untitled.jpgLike this:
    You have to click placement tab> details and select all the curves by pressing control key while creating flange. File is attached.
    In model --> to select a surface or datum --> Engineering --> ECAD area --> Sketch the profile --> OK
    --> (Area Type) Place keepout, Option: 3D Volume, Depth options, depth .xxx , Ok --> you will see a surface image attached to the part.
    Flange feature
