How to create a profile like attached image in pro/e sheetemetal
ptc-4510561
Untitled.jpgLike this:
You have to click placement tab> details and select all the curves by pressing control key while creating flange. File is attached.
In model --> to select a surface or datum --> Engineering --> ECAD area --> Sketch the profile --> OK
--> (Area Type) Place keepout, Option: 3D Volume, Depth options, depth .xxx , Ok --> you will see a surface image attached to the part.
Flange feature
