Importing Layers
josh.stamps
Importing Layers
Is there a way to import layer trees? For example, I often times import cad models from vendors of various fittings, valves, etc. I spend too much time creating and naming layers to correspond with my companies standard layer naming convention for designed parts.
3 REPLIES 3
As per my knowledge you can try out with two options 1. There is a toggele button in model tree to select Layer tree. If you activate Layer tree you will find Settings>>Setupfile>>Open You can import your file pre-formatted as per Proe layer file. 2.You can create a macro to create Layers and can use it repeatedly.
3. You can create an empty part from your start part and import a step file into it.
ModelCheck can be configured to do this.
