Manually create an inspection box?
CADQueen
@[ can be used to draw a graphic basic box around a value. Like this: @[@D@]
Is there an equivalent for the inspection box also referred to as a "sausage"? I can't seem to find it if there is.
2 REPLIES 2
select (or create) the dimension
rmb properties
under display there are three radio buttons, one is Inspection.
Selecting this will put a "sausage" around the dimension
Let me clarify.
If you use the "Inspection" or "Basic" radio button everything is put inside the box. (That's how I made the images I showed).
But what if you want to do something like this:
You can type add a @[ and a @] around the dimension and type the 4x in front of all of this.
How do I do this with an inspection sausage?
