Model Comparision in Parametric?
jmayer
Is there a way to quickly compare two models, the old revision vs. the new revision? Highlight changed faces or some other indication of a change?
Jason
GaryLinscheid
(To:jmayer)
Try this.
TomU
(To:GaryLinscheid)
Of course if you're in a Windchill environment this will prove more difficult because (unless something changed) you can only have one version of a part in your workspace at a time. You will have to make a temporary copy of one version of the part (as a different name), and then download the other version you want to compare to.
jmayer
(To:jmayer)
Using part compare, geometry did not produce very good results (in my opinion).
I ended up using Creo View to compare the different revisions of the same model. I am using Windchill but Creo View allows you to add more then one part version at time.
