Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Could someone please give me a listing of or a location of the discription/meaning of each of the Icons that are possible in a Model Tree; an example is the Double Bars, which indicates not fully constrained, etc. Thank you, Warren
They are actually called Glyphs - apparently.... To get the definition try the following in Pro/E: Help>Help Center In Quick Search enter Glyphs - you should get a link to "Understanding Glyphs in the Model Tree" which should help to explain them all.
Thanks for posting the link. I have been after an explanation of the model tree symbols for a while but didn't know they were called Glyphs. Cheers Martin Ashton
