Modifying hidden line
mselamat
Hi, how to change hidden line colour for Pro Engineer Wildfire 5.0?
John.Pryal
(To:mselamat)
Hello, you need to click View, Display Settings, System Colors. You then select Hidden line & change the colour. If this is to be permanent you will need to save a new system colors file in your load point directory & point your config.pro file at it.
Regards
John
3 REPLIES 3
John.Pryal
(To:mselamat)
Regards
John
you can change your color scheme according to your needs.
View > Display Settings > System Colors > Graphics tab > Hidden Line item
MH
Martin Hanák
Hi John & Martin,
Thank you. It simply works!
Muzzammil
