NPT hole chart
ptc-438677
NPT hole chart
Does anyone know if a standard hole chart exists for NPT style holes? Cheers, Lucy
30 REPLIES 30
Lucy, Put your email up on your profile and I will send it to you. Regards
Dear Peter, My Email address shows up now. If you could email me an NPT hole file I would be grateful. Thanks so much for your help. Lucy
I would also be interested in the NPT file as well. This would be extremely helpful. Thanks, Ben
I would also be interested in the NPT file as well. Thanks DKL
You will need to enable your email address, as files cannot be uploaded to this site.
Please supply me with a copy of your much needed chart.
I have to email the hole file; you have to edit your settings to enable it so I can see it.
Peter, I would also appreciate a copy if you the time. Aaron Soucy Solar Turbines
Dear Peter, I would also be interested in the NPT file as well. My email address is mps@ltdemag.com Regards and Thanks M.P.Saju
I would also be interested in the NPT file as well. email id : venugopal@cimtechsystems.in Thanks venu
I would also be interested in this NPT file! My e-mail address is a.leader@argo-hytos.com Thanks Aaron
Not applicable
(To:ptc-1541251)
can anybody tell me what is NPT hole chart I have never heard about this.
ptc-1427881
(To:)
Pipe Thread
Not applicable
(To:ptc-1427881)
thanks Steve
ptc-691619
(To:)
Please send me copy of the NPT chart, I would like to use it with WF 2.0, will it be compatible ?? thank you Russell russell@prestatec.com
I'd like a copy also if possible. thanks zfarkas@asu.edu Arizona State
a copy of that hole chart would be much appriciated thanks john
Is any body interested in a UDF based solution for this with facility for changing the 3D note as desired ?. [/img]
YES THE UDF APPROACH WOULD BE INTRESTING TO LOOK AT
I would like to receive as well. Thank you in advance, Curtis cfaulk@mii.com
Any Chance someone could e-mail this to me? Thank you!
I would like a copy of this NPT file as well! Thanks in Advance, Kathy
I could use the UDF file. Thanks
I'd like a copy also if possible. thanks - Portugal
If anybody is interested in the Udf files for NPT and BSP ports with customisable 3D-note attached, please send e-mail to self (mps@ltdemag.com). I am at the moment, interested in your feedback on its use and therefore, am giving it free. A note of caution: This has been developed in Wildfire 2.0 (M120). I have not tried it in Wildfire 3.0 and therefore do not have any experience in that environment. The feature works with X and Y co-ordinates from two perpendicular surfaces and is inserted on the third surface perpendicular to both of the above. If you want axis based, I have a separate udf for the same. The cosmetic of the NPT thread is only a representation and does not have a taper. Best regards M.P.Saju (mps@ltdemag.com)[/code]
I'd like the .hol file also please, does it do the tapered bore and cosmetic thread?
If someone could send this to me I would be very grateful to.
