anonymous wrote:
1.00000000 0.00000000 0.99799331 0.00036522 0.99198809 0.00145219 0.98202615 0.00323861 0.96816880 0.00569834 0.95048690 0.00881433 0.92920588 0.01237637 0.90451466 0.01645622 0.87648374 0.02123403 0.84556226 0.02680163 0.81180321 0.03308275 0.77537373 0.03996767 0.73699103 0.04733843 0.69648100 0.05519045 0.65449658 0.06339765 0.61134464 0.07179496 0.56702868 0.08033999 0.52256617 0.08829137 0.47741597 0.09585161 0.43302357 0.10200580 0.38857262 0.10745148 0.34555731 0.11138214 0.30356427 0.11408964 0.26313877 0.11529117 0.22456275 0.11508254 0.18814776 0.11339912 0.15455522 0.10978344 0.12344136 0.10437932 0.09543672 0.09649843 0.07075211 0.08608142 0.04950788 0.07367000 0.03190809 0.05965034 0.01796495 0.04519710 0.00803419 0.03097149 0.00201450 0.01575134 0.00000000 0.00000000 0.00201122 -0.00872928 0.00804129 -0.01810995 0.01807760 -0.02690123 0.03186015 -0.03493114 0.04952337 -0.04272818 0.07080405 -0.04909225 0.09555106 -0.05435719 0.12348744 -0.05898124 0.15438928 -0.06246153 0.18837516 -0.06540494 0.22456620 -0.06779466 0.26300815 -0.06952412 0.30341815 -0.07071256 0.34549305 -0.07121973 0.38890269 -0.07084584 0.43279120 -0.06970918 0.47772669 -0.06728644 0.52232870 -0.06423813 0.56722231 -0.06025593 0.61118977 -0.05600225 0.65454600 -0.05134065 0.69654128 -0.04650305 0.73690182 -0.04149645 0.77552429 -0.03623413 0.81169896 -0.03109746 0.84552700 -0.02595276 0.87659483 -0.02104637 0.90450110 -0.01657841 0.92923350 -0.01250117 0.95048354 -0.00891788 0.96811806 -0.00583042 0.98199079 -0.00332218 0.99197665 -0.00148319 0.99799150 -0.00037147 1.00000000 0.00000000
"Kevin DeMarco" wrote:
Change the file to a .pts file. Delete the last row since it is a duplicate of the first row and add a third column to the text file and enter zero on each row to get the data in x, y, and z coordinates. Create the points using the Offset Coordinate System Datum Point tool. Select the coordinate system and import the points from the .pts file. You can then create a datum curve feature through the whole array of points.
