Need to prevent a Spotlight from shining through solid components. I have selected shadows but the light still shines through. I even put a plate which has non transparency properties right in front of the spotlight and it shines through it onto other components behind the plate. I have all other lighting (default, back, etc) turned off.
please tell us what version you are using. Also attach a picture and upload Creo data, if you can.
MH
Using Creo version 2.0
in case that you are active customer I suggest you to open Case at PTC Support.
I did test in CR2, CR3, CR4 ... your problem is reproducible in interactive shading mode in all versions.
In CR4 I tested light behavior in Render mode with Keyshot renderer ... in this case result was correct.
In CR2, CR3 I was not able to produce correct result with Photorender/Photolux renderer - I think because I do not have the appropriate knowledge
My guess:
Maybe Vladimir Palffy can explain the situation.
MH
Hi all - Martin you are right
" realistic results are produced in rendering mode, only"
Sorry Edward
, If you would like see your final results - you need to use Render Region or Render final objects.
Regards, Vladimir
