Need to prevent a Spotlight from shining through solid objects. I have selected shadows but the light still shines through. I even put a plate which has non transparency properties right in front of the spotlight and it shines through it.
edeselm
Need to prevent a Spotlight from shining through solid components.  I have selected shadows but the light still shines through.  I even put a plate which has non transparency properties right in front of the spotlight and it shines through it onto other components behind the plate.  I have all other lighting (default, back, etc) turned off.
4 REPLIES 4
please tell us what version you are using. Also attach a picture and upload Creo data, if you can.
MH
Martin Hanák
in case that you are active customer I suggest you to open Case at PTC Support.
I did test in CR2, CR3, CR4 ... your problem is reproducible in interactive shading mode in all versions.
In CR4 I tested light behavior in Render mode with Keyshot renderer ... in this case result was correct.
In CR2, CR3 I was not able to produce correct result with Photorender/Photolux renderer -  I think because I do not have the appropriate knowledge .
My guess:
  • in interactive shading mode Creo is not able to solve lighting realistically
  • realistic results are produced in rendering mode, only
Maybe Vladimir Palffy can explain the situation.
MH
Martin Hanák
Hi all - Martin you are right
" realistic results are produced in rendering mode, only"
Sorry Edward , If you would like see your final results - you need to use Render Region or Render final objects.
Regards, Vladimir
Best Regards,
Vladimir Palffy
