Community Tip - You can subscribe to a forum, label or individual post and receive email notifications when someone posts a new topic or reply. Learn more!
X
Is there a way to have the parameter window open the same every time. The same order, same column widths, and the same window size. I have to adjust the column width every time I open the parameter window. Using WF2.
Yes how ULTIMATELY annoying! Please let me know too if you hear of a way. Thanks, Mark
>>> "Cass, Brian P" <-> 2/9/2006 12:13 PM >>>
Pro's, Is there a way to have the parameter window open the same every time. The same order, same column widths, and the same window size. I have to adjust the column width every time I open the parameter window. Using WF2.
You are currently subscribed to model. To unsubscribe send a blank e-mail to -.
