Possible to add radius to sheet metal bend note?
ptc-4658678
1-Newbie
Hi, quick question from sheet metal newbie:
Is it possible to add the bend radius to the sheet metal bend note, if so how? And is it possible to automate the process?
regards, audun
ekoubi
(To:ptc-4658678)
Hi Audun,
starting from Creo 3, it will be possible to add &inner_radius and &outer_radius to the smt_bend_notes_order config to add the actual inner & outer bend radius of the bend.
3 REPLIES 3
Hello
I have just posted exact same question here, but not answered yet. Wondering if you have found solution?
Regards
Andy
Audun,
You may try config option smt_bend_notes_order with value as &type&direction&angle R&SMT_DFLT_BEND_RADIUS
"R" is to show radius for &SMT_DFLT_BEND_RADIUS
ekoubi
(To:ptc-4658678)
Hi Audun,
