Has anyone come across user manual or any help file of pro program?
Regards
Ketan
Tom, you are absolutely right. I shouldn't touch somebody's work until I FULLY understand it. Unfortunately here I have the limit of 80 characters which I cannot split on the contrary of Pro/Program.
Even the person who initially did the job had a mistake with a couple of lines. For a fortunate series of events, that instances have rarely occurred.
Now I'm trying to remember from school the use of logical expression. I think I could say that the expression
IF PAR == "1" | PAR == "2" | PAR == "3" | PAR == "4"
IF RAP == "A" | RAP == "B"
SET STATE MY_STATE
ENDIF
ENDIF
I could split it in eight blocks
IF PAR == "1"
IF RAP == "A"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "1"
IF RAP == "B"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "2"
IF RAP == "A"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "2"
IF RAP == "B"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "3"
IF RAP == "A"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "3"
IF RAP == "B"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "4"
IF RAP == "A"
SET STATE MY_STATE
ENDIF
ENDIF
IF PAR == "4"
IF RAP == "B"
SET STATE MY_STATE
ENDIF
ENDIF
There are only TWO PARAMETERS: PAR and RAP and one View State.
Is there something that seems wrong above? Is there any variant to combine two of the blocks?
And I still can't find some help for Drawing Program and View States. I thing I should experiment by myself as Martin said.
Nic.
I do not understand why you are still solving IF command. From my point of view, situation is clear.
MH
I would say the first version is probably the best, but if you can't fit everything in 80 characters then you will have to split it up.
There is nothing wrong with the 8 individual versions, but you could simplify them some if you want to. For example:
IF PAR == "4" & RAP == "B"
SET STATE MY_STATE
ENDIF
If line length allows you could also just drop down to 4 versions. For example:
IF PAR == "1"
SET STATE MY_STATE
ENDIF
ENDIF
Finally, it will make it less readable, but you could always convert the values your comparing on to something shorter. This will help you avoid the line length restrictions. For example:
/* Set BS equal to an integer representing it's actual value
BS = 0
IF BSHAPE:1 == "TRUNCATED"
BS = 1
ENDIF
BS = 2
ENDIF
IF BSHAPE:1 == "TRUNCATED WITH INCL"
BS = 3
ENDIF
/* Now do the comparison with the shorter values.
IF BS == 1 | BS ==2 | BS == 3
SET STATE MY_STATE
ENDIF
/* Since you've switched to integer values, you can also do math comparisons
IF BS >= 1 & BS <= 3
SET STATE MY_STATE
ENDIF
Hopefully that gives you some ideas. ![]()
Thank you, Tom.
Yes, you gave me some ideas but I supposed the most readable version, for the people that will touch the model after me especially, is the longest one. It is simple, clear, divided in easy to read and understand blocks and is long (the only downside of this solution).
Nic.
Here is the guide from Widlfire 2.0. http://www.datajett.com/Cadd/ProE/Wildfire_Help/program.pdf
There was a guide from Wildefire 4.0 but can't find that one. However, they are basically the same.
