"Don Rutledge" wrote:
Attached is a copy of the web page from that link. A "drafting convention" is just an agreement on how to symbolicly represent real geometry. A "CAD modeling convention" is just an agreement on how to symbolicly represent real geometry. You really should look at the model I sent and see what it looks like, and what it looks like on an assembly drawing. I don't think it's misleading at all. If you want simulate reality then go ahead and model the actual threads. (And get a bigger computer).
as you can see, I cannot access the field for changing or even writing a new command line. (As far as I am in the right menu... I got there by clicking on Tools-Options when being in the 2D-drawing mode. is that correct?) If it is: could it be possible to edit the config.pro directly? (I think the commands schould be in there, aren't they?)
I've also uploaded my config.pro as a .txt file: http://uploaded.to/file/68brwu Do you have any ideas? I cannot imagine, I am the only one with such problems...
Today we also tried to open the file on another computer. but we had the same problem there. I think the problem is somewhere hidden in the data itself and not in the program. We also tried to delete the old .drw file and created a new one. just the same problem. If we opened any other construction, the threads were visible. Somehow I'm getting depressed...^^
