Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
per: https://www.ptc.com/appserver/cs/view/solution.jsp?n=/117891.htm i can't seem to get this to work properly. does the environment variable need to be a system variable? also, should the path be in quotes to accept the spaces? any help is appreciated.
