Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
SKETCHED Line Thickness
agaribay
3-Visitor
Is there an option to modify the SKETCHED Line Thickness?
Being color blind, it can be a challenge when working with complicated
parts....Doh!
Thanks in advance!
-Art
ProE Wildfire 2.0
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
Is there a way to change the SKETCHED Line Thickness in WF2? It would
be nice if the sketched entities were bolder.
Thanks you.
-Art
lwh
(To:agaribay)
Changing the thickness is only possible for plotting.
You can change the color, though: View > Display Settings > System Colors and change the Sketch color.
Then save the settings to a file. You can copy the file contents to Your config.pro to load it automatically.
Did you try the "SHADE CLOSED LOOP" option? That helps a bit...
though, my biggest complaint about that is I can't set it to be ON as a
default... Can't set the "HIGHLIGHT OPEN ENDS" or "OVERLAPPING
GEOMETRY" sketcher helps as default on either... grrrrrrrrr...
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
Also being color blind, I found that playing with the line colors until you get a good contrast... or you could change the line font -give sketched lines a phantom or abroken font. Have you tried that?
