Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Here is a screen shot of eDrawings 2009 viewer file open dialog box. Pro/E files are an explicit option:
When you go to download the eDrawings viewer (may ne be true for the publisher download) there is a page where you can check "Yes, I want to view 3D XML and PRO/E files using eDrawings viewer":
