Is there some setting, perhaps in the ProductView, that will turn off the creation of the .log file when I Save a Copy as edz in Pro/E?
Hi
I've seen pro-e does the same thing if you export a drawing as dxf.
I use this often to send a laserdrawing of a part.
Anyone?
Chris
