Server registration location
davehaigh
I'm getting ready to roll out Creo 2.0-m120 and I'm noticing a change from the earilier versions I've run
All of my startup script have a line to remove srv_mgr_db.fldx from the APPDATA folder.
Recent revs have stored it here:
del "%USERPROFILE%\AppData\Local\PTC\Creo\Platform\2.28\agent\ServerMgr\.srv_mgr_db.fldx"
At one point it was in Roaming instead of Local
Now I don't find it anywhere in m120.
Did they get rid of this?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
3 REPLIES 3
AndyHermanson
(To:davehaigh)
Here you go David.
"%USERPROFILE%\AppData\Roaming\PTC\Creo\Platform\ServerMgr
sm
(To:AndyHermanson)
Thanks, I was searching everywhere for this. I kept dropping the files from %USERPROFILE%\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf and then they would magically reappear when I restarted Creo 3.0. Good to know this stuff is now stored in a new location and a new file name.
davehaigh
(To:davehaigh)
PTC responded to me. Woo Hoo!!!!
They got rid of this starting in m110. I'm glad, because it was a pain since the path changed with each release, and I had to modify my startup script each time.
Here's the details.
Technical Area:
Integration with Windchill Solutions
Release:
2.0
Product:
Creo Parametric
Last Modified:
2014-04-25 03:33:42
Title
When upgrading from one Creo Parametric Maintenance Release to another, Secondary Servers are not retained in Server Registry
Description
* When upgrading from one Creo Parametric Maintenance Release to another, Secondary Windchill servers are not retained in Server Registry
* Secondary Windchill servers are no longer listed in Server Management after installing a new version of Creo Parametric
Applies To
* Creo Parametric 2.0 M100 and earlier
* Windchill Solutions All Releases
Cause
* Primary and Secondary Server Registry information is maintained in %localappdata%\PTC\PTC\Creo\Platform\2.xx\ServerMgr\".srv_mgr_db.fldx where the 2.xx directory is unique per Maintenance Release. On start up of a new Maintenance Release, only the Primary Server registry detail is copied from the previous release directory to the new release directory.
Resolution
* Reported to R&D as SPR 2212082
* Software fix expected for Creo Parametric 2.0 M110
* Server registry information (both primary and secondary) will instead be written to %PTC_WF_ROOT% and will will not change between Maintenance Releases
* Workarounds:
* Copy previous Maintenance Release .srv_mgr_db.fldx file into the latest version of the file
* Shutdown Creo Parametric
* Kill the creoagent.exe process
* Backup %localappdata%\PTC\Creo\Platform directory content
* Copy contents of the previous release %localappdata%\PTC\Creo\Platform\2.xx directory to the new release directory, for example:
* Copy contents of %localappdata%\PTC\Creo\Platform\2.27 to %localappdata%\PTC\Creo\Platform\2.28 (if upgrading from Creo 2.0 M070 to Creo 2.0 M080)
* Merge previous Maintenance Release .srv_mgr_db.fldx file entries into the latest version of the file
* Merge contents of the previous release %localappdata%\PTC\Creo\Platform\2.xx\ServerMgr\.srv_mgr_db.fldx into new release .srv_mgr_db.fldx file
David Haigh
