Sketch view refresh problem
rdimitrov-2
Hi All ,
Here is my problem,
First i will start with my pc configuration:
CPU: Athlon X4
VGA: some radeon card with 1gb DDR5
Ram: 8GB DDR3
SSD hard drive
So i am using Creo 3.0 and the problem is that when i enter the sketch and try to move the view around the planes(whit middle button of the mouse) it didnt refresh and all i see is a lot of lines. the problem exist only when i am in the sketch.
Thanks in advance and have a nice day!
Radoslav,
start with well known trick, add the following option at the end of config.pro file.
graphics win32_gdi
Test Creo.
Martin Hanak
Martin Hanák
4 REPLIES 4
Radoslav,
graphics win32_gdi
Test Creo.
Martin Hanak
Martin Hanák
Hi Martin,
I want to thank you, it works now everything working great !!!
Radoslav Dimitrov
Radoslav,
now you know that the problem is related to graphics drivers. So the next step is to remove graphics win32_gdi option from config.pro and update graphics drivers. This step enables Creo to use OPENGL graphics instead of Windows WIN32_GDI graphics.
Martin Hanak
Martin Hanák
Good day Radoslav,
I am glad Martin Hanak‌ was able to help; would you please set his answer as correct so those who may be following this discussion or may search this topic in the future?
Thank you,
Toby
