Summary: Easy parameter editing
dgschaefer
Here's what I found in both WF3 & WF4.
The best solution was Olaf's mapkey:
     mapkey mm #modify;#value
This brings up the old 'Modify' menu and you can single click on each
parameter to change them.  Perfect.
LinkedIn
2 REPLIES 2
Hello Doug,
you can still edit the parameter embedded in the note by single-clicking the note to select it, then hover over the parameter to prehighlight it and double-click to edit the parameter.
Jurij Škraba
Research & Developement Department for Hydromechanical Equipment
Litostroj Power | Production of Power Generation and Industrial Equipment |
Jurij,
That's true in drawing mode, but not for 3D notes in part or assy mode, which was what I was asking about.
Doug Schaefer
LinkedIn
