you can still edit the parameter embedded in the note by single-clicking the note to select it, then hover over the parameter to prehighlight it and double-click to edit the parameter.
Regards, Jurij Škraba Research & Developement Department for Hydromechanical Equipment Litostroj Power | Production of Power Generation and Industrial Equipment |
