Summary: Easy parameter editing
dgschaefer
Here's what I found in both WF3 & WF4.
The best solution was Olaf's mapkey:
     mapkey mm #modify;#value
This brings up the old 'Modify' menu and you can single click on each
parameter to change them.  Perfect.
LinkedIn
Hello Doug,
you can still edit the parameter embedded in the note by single-clicking the note to select it, then hover over the parameter to prehighlight it and double-click to edit the parameter.
Jurij Škraba
Research & Developement Department for Hydromechanical Equipment
Litostroj Power | Production of Power Generation and Industrial Equipment |
Jurij,
That's true in drawing mode, but not for 3D notes in part or assy mode, which was what I was asking about.
Doug Schaefer
LinkedIn
