Teble Issues
cdown
7-Bedrock
Teble Issues
I'm back using wildefire 4 M220, I am struggling to remember how to change a table from descending to ascending, any help??
5 REPLIES 5
StephenW
(To:cdown)
On WF 4, once you build the table, I don't think you could change it.
The original dialog to build the table had a ascending/descending selection.
cdown
7-Bedrock
(To:StephenW)
I thought that might of been the case, I knew you used to be able to do it in WF2
StephenW
(To:cdown)
I don't remember ever being able to change it until Creo came around using right click Properties.
I thought it was always one of those you get one chance to get it right things
hi,
for a hole table, is it possible to have relative dimensions (in either wf3 or creo 3/4, as we will transition "soon")
Hole tables are generally used so that a CNC programmer can have absolute coordinates to work from.
How would relative dimensions be used?
