Threaded holes in WF5
mike_pavese
They say the only dumb question is the one you don't ask, well; Question: Why in the "hole dialog" when you choose taped holes the only available choices are UNC, UNF & ISO in the "pull down menu" when (in the same load folder) are NPT, NPTF .hol files, why don' these show up in the menu?
TIA.
Mike Pavese -
In Reply to mike pavese:
Well, its nice when you can answer your own question, I guess. I needed to select "tapered hole" and the other NPT, NPTF show up in the dialog. Thanks to all.
TIA.
Mike Pavese -
