Thru hol tables
tfroud
Thru hol tables
Does anyone know if you can set up hol tables so they are automatically
thru holes with no countersink, or clearance holes with countersink etc?
I am trying to set up tables for different scenarios.
Tim
Tim Froud
Mechanical Engineering Group
R25, Room 1.52
Space Science and Technology Department
Rutherford Appleton Laboratory
Chilton, Didcot
OXFORDSHIRE
OX11 0QX
UK
Tel: +44 (0) 1235 778101
Fax: +44 (0) 1235 445848
<http: www.sstd.rl.ac.uk="/>
The contents of this e-mail are sent in confidence for the use of the
intended recipient only. If you are not one of the intended recipients
do not take action on it or show it to anyone else, but return this
e-mail to the sender and please delete your copy of it
0 REPLIES 0
