Tool parameter doesn't get updated ?
Manikandan
I gave the default speed and feed for each tool and when I call the tools for operations like Roughing,finishing etc.. the default value doesn't get updated.
Give me some suggestions how I solve the issue.
6 REPLIES 6
I have the same problem since a long time. I'm interested also in this question...
Maybe try to change this in your options setting,
Larry
BillChapman
(To:ljanssen)
If you want this to automatically populate without any selections (and update if you change materials) you should use relations in your site file. Something like:
CUT_FEED =TOOL_ROUGH_FEED_RATE
STEP_OVER =TOOL_ROUGH_RADIAL_DEPTH-.005
SPINDLE_SPEED=TOOL_ROUGH_SPINDLE_RPM
STEP_DEPTH=TOOL_ROUGH_AXIAL_DEPTH
Thanks Bill for this grate tip, it works perfectly !! What a lot of time i'm going to save.
Thank you all ...It works perfectly.
I suppose you know.., you can set tool conditions for different materials and then use them in your manufacturing model selecting the stock material:
