Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Not sure if you Wildfire users are aware of this but For those of you who use the new transparent workpiece functionality When you open pre wildfire mfg models the transparency does not come into effect To convert the workpiece to transparent select Mfg Model - Reclassify and select the workpiece
