WF3 Build Comparison
roger.willson
Update Advisor told me this:
This tool has been taken offline for significant maintenance. Look for a
new Update Advisor in the summer of 2008
Does PTC have an alternative solution until the Summer of 2008?
Cheers,
Roger Willson
Global CAD Manager
SRAM Corporation
1333 North Kingsbury
Chicago, IL 60622
312-664-8800 x1358
All I can say is to avoid M120. It's a clunker. I've had two show-stoppers already, one where some drawing files cause ProE to exit when opening them and the other where it completely messed up my plotting, rotating the plots 90 degrees from all prior versions, clipping them, etc. They've been reproduced and SPRs created (the plotting issue), but Support told me to de-grade to M110 and wait until M130 for the 'exit' issue.
Regards
Roger Willson wrote:Update Advisor told me this: This tool has been taken offline for significant maintenance. Look for a new Update Advisor in the summer of 2008 Does PTC have an alternative solution until the Summer of 2008? Cheers, Roger WillsonGlobal CAD Manager SRAM Corporation1333 NorthKingsburyChicago, IL 60622312-664-8800 -
I have a contractor (using M120) experiencing the same issue with
drawings exiting. I've been using M100 without any issues, so I would
recommend that as well.
Tony
