Weight in Bill of Material
mcad_user
Hi I want the weight of the model in ProEngineer Bill Of Material created by using the repeat regions.I have added the parameter(weight) in relations and i want only that perticular parameter value to be extracted in Repeat Regions.Can anybody suggest me any
5 REPLIES 5
Not applicable
(To:mcad_user)
In repeate region you should select asm.mbr.User Defined then, pro-e asks for the parameter name, now enter the parameter name (weight in your case) Then update the table.
mcad_user
(To:)
Thank Prashant But it is not working See I have added the parameter weight of which the source is Relations not the user defined so I think it is not working. Is there any other solution
Not applicable
(To:mcad_user)
it is a case sensitive so see that the case in parameter and you have typed are matching.
Not applicable
(To:)
this method reads the parameter only and nothing to do with the relation or how it is computed. it just takes the value of user defined parameter.
ptc-1428410
(To:)
hi it will work but before u have to set that Tools -> Options -> mass_property_calculate ->Automatic i think it will work venu
