What is the correct ProSelect filter to pass as parameter 1 to select snap lines?
pwilliams-3
I want the user to select a snap line.  What is the correct ProSelect filter for parameter 1?
PTC Technical Support and others within the community confirmed that this is NOT possible (Creo Elements Pro Wildfire 5.0).
