Can I automatically suppress multiple features at one time within Creo? For example, can I define a rule that says to suppress all holes with a diameter of 6mm or less?
Pretty sure you can do that through Pro/Program (Program). An IF THEN ELSE statement(s) should get you the results you want.
Explore the search tool.
For example:
You can create a search with two rules, the first select all the hole features like shown above:
the second rule select the ones that have the pretended dimension:
You can save this query too for later use.
Explore a little this tool to see how powerful it can be.
Another option is to create a layer with the previous rules, then you just have click on the layer, "select items" and "supress".
I found recently that is possible to copy layers from one model to another, this is really handy because you can have a model with all these layers with associative filters and just copy paste it to another.
Jose
Can you please confirm that "AND" works correctly is this specific case? In Creo 3 M050 it seems to be ignoring the "AND" and treating the compound query like "OR".
Yes, the "and" condition is working. The problem is that this filter selects all kind of dimensions, not just diameters.
Creo 2.0 M110
José
After some more tests, I realize that the "and " operator doesn't always work, sometimes the results aren't the expected...
Anyway, for this case, I played a little more with the tool and isn't easy as I expected. I could make it work but not in a very elegant way....
First create a new layer (example "holes"), create rules for it and make them associative.
I had to create 3 rules to make it work:
The filter is on, now select only the features in layer tree (don't select the dimensions), switch to feature tree, RMB-> Suppress
There might a cleaner way to do this, but this is the best I achieved.
Jose
Not easily, and not without advance planning. If this is a model that you have full control over and want to build automation into, then yes. If you simply want to open anyone's model, locate fasteners by size, and create a rule to suppress, then no.
Here are the steps to automate with Pro-Program:
Example (d18 is the hole diameter):
IF D18 > MIN_SIZE
ADD FEATURE (XXX)
END ADD
END IF
