Wildfire launcher for Windows 7 taskbar
David_M
While Creo has nice taskbar integration, Pro/E won't even pin properly. For all my efforts I haven't managed to get a Pro/E icon that looks like Pro/E to launch the app and be grouped with the open windows.
I wondered if anyone had written their own launcher for Pro/E that shared the necessary tags to be grouped with the Pro/E windows? If so, please could you share it?
Interesting document.
I finally made it work. A working launcher is attached. I have the 64 bit version of Wildfire 5 installed, so this will group with that. You'll need to open the properties for the shortcut and add your Pro/E start-up directory in the start-up directory box. You may or may not have to point to the icon yourself, which is called xtop.ico. What could be simpler?
6 REPLIES 6
I've been ticked about the same thing. Let me know if you learn a fix.
KrisR
(To:David_M)
While I can't get an icon to stick (we use a batch file to load Pro E/Creo 5), mine do group.
David, yours do not group?
Yeah, open windows will group, but they will not group with the pro-e application shortcut that is pinned to the taskbar.
How do you write in the batch file where to find configuration files?
Well, I didn't create the batch file.
I tooka minute to look on the forums here about batch files, didn't see anything specific to create it. Maybe take a few more moments than I did and you might be able to find something.
Sorry, I'm digging to deep.
I'm browsing the following document to find some batch file tips:http://communities.ptc.com/docs/DOC-1281#comment-1475
