full view simbol +
bcat
9-Granite
full view simbol +
i want + to view full black , same a blod font how make this
thanks
2 REPLIES 2
RonSt.Pierre
(To:bcat)
if you extruded it in the model, you could change the surface color.
if you create it as a cosmetic sketch with xhatch, then when you get to the drawing, you can close the spacing of the hatch
ron
Mahesh_Sharma
22-Sapphire I
(To:bcat)
Bodgan,
Did the information from Ron help you?
Another option which you can try (it will not be a complete solution) is adding x-hatching in the sketch.
Create a sketch > Redefine the sketch > Sketch setup > Properties tab > Check add cross hatching > Add minimum spacing and finish. There is no fill option for sketch hence this may give you close results.
