previously while using the measure option ( proe 4 or proe 5) i could do this, to get the measurement along coordinate system.
but know in creo 2.0 , it does not give the reference of x and y along coordinate system.
it just gives the measurement in a box.
That is what those delta references are in the dialog.
It is using the CSYS projection reference from the expanded measure distance dialog box
thanx for the reply.
i know those dimensions are shown in that box....but as you can see the reference line in the image from proe 5.....those reference lines are missing in creo 2.0...
True. I am not impressed with the new measuring scheme at all.
If you use a datum plane as a projection reference, it will at least draw dashed lines to show what the reference is related to.
