geometry intersecting a line
Chris3
Does anyone know of a way to determine the thicknesses of all geometry
intersecting with a line? That is I would like to draw a line at a given
angle and see a report listing the component and the wall thickness (or
thicknesses) of each component that the line passes through.
Chris
2 REPLIES 2
CM10
(To:Chris3)
You should be able to draw your 3D line (datum curve) and then place datum points along the curve on the line where the surfaces intersect.
mlocascio
(To:Chris3)
Exactly!
