this should be an easy one for all you guys out there.
How do I make these dimensions larger?
Doesn't the hidden config control this?
Found it - again. http://www.synthx.com/tom/sy_tip_0307.htm
TEXT_HEIGHT_FACTOR 40
This might help read the text better:
enable_transparent_text_bg *yes/no
David, that is not doing anything for me in Creo 2.0... at least not in session.
edit: I take it back... it takes affect after a while ![]()
Isnt this controlled in the .dtl file in the part or assembly? I dont have access to Creo right now to look but i think you can control it there or in the properties menu for the dims.
You might add an addendum to your support case ![]()
It wouldn't be the first time CS was up for learning something new... or old... whatever.
The only response to that is "WOW!"
Why bother implementing a good idea.
I can confirm that it does work. I'm using Creo 3.0 M020.
Although you can't search for it, you can enter it manually into the configuration options.
I love this group.
Thanks to all of you that help.
-Joe
