Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Well I have been using pro/e since a long time. Can anyone tell the method for offsetting a profile in sketcher.some times profiles are complicated and imported from other softwares but we find it difficult to offset the profile
