Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Can you change the parameter name?? While creating the parameter, I was able to rename it. But, once I ok'd and went back I wasn't able to rename the parameter. I had to go and delete the parameter and recreate it.
I've searched the knowledge base and found no results.
