hello
I have modified start.mcs file to create a new parameter (drawn_by) in model and i want to pick the value of this parameter from drop down list so i have modified the start.mcs file a
PRT_PARAMETER DRAWN_BY STR EQ LIST_DESIGNERS
STD_USER_LIST_FILE designers.txt
and also the designers.txt file contains name of list of designers in defined way , and file also placed inside text folder.
but the result is not showing as expected.
on the other hand if add all the items of designers.txt file to start.mcs the result it is showing is correct.
please find the images for more clarification
Is this really the proper use of ModelCHECK? ModelCheck is designed to check a file to see if it meets your company defined standards.
I know you can add things to a file, like the spell check file, and can change parameter values, but adding a designer's name to a part parameter seems to be going too far.
I would use a restricted_text.dat file for the designer parameter and have the person designing the part select their name from the drop down list in the parameter editor. This can also be done at the drawing level.
Just my $0.015 comment.
Ben
Windchill 10.0 m040
Creo2 m100
This is a configuration problem:
You must define the name of the list
STD_USER_LIST_FILE LIST_DESIGNERS designer.txt
