Frame joint
  • February 8, 2016
  • 2 replies
  • 3090 views
Does anyone know how to remove the rest of a frame when it has been cut using another profile?
I am using PTC Creo Parametric 2.0.
In order to clarify the question I am including a picture below.
Cheers,
Enrique
    why don't you use the bigger profile to cut ?
    erguezga1-VisitorAuthor
    Well, I need to use that frame, not any other...
    I guess you have used cutout feature. Remove it nad use common assembly cut (you can define its sketch using profile surfaces/edges and enlarge it to remove unwanted geometry).
    MH
    You are right, that is one solution, but I am searching for a solution inside Advanced Framework Extension to not to lose any of the advantages of this tool.
    Thanks anyway.
    in case of AFX I suggest you to post your question under Advanced Framework Extension - AFX group. I hope people from B&W Software GmbH - Solutions for efficient product design: Unternehmen will help you to resolve the problem.
    Following users are mentioned in the group:
    Samuel Brantner
    Jan Stothfang
    MH
