rcover a Parameter
s.touret
rcover a Parameter
Hello, How can i recover the name of the model (&model_name) in a parameter. I tried with the relations but it doesn't work. Thanks
3 REPLIES 3
sdick
7-Bedrock
(To:s.touret)
I tried a one line relation : NAME=rel_model_name() and it works fine... Why did you create a string length parameter before ?
s.touret
(To:sdick)
That's works fine! Thanks a lot! regards
Try these relations strlen=string_length(rel_model_name()) name=extract(rel_model_name(),1,strlen) where strlen is a "Integer" Parameter and name is a "string" Parameter
