Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Try these relations strlen=string_length(rel_model_name()) name=extract(rel_model_name(),1,strlen) where strlen is a "Integer" Parameter and name is a "string" Parameter
