relations ~ adding one to define a raw material number.
jason.webb
Help, I am trying to assign a raw material number based on a tubes height, width and thickness through IF statements. Any suggestions?
3 REPLIES 3
Thanks Ben Loosi for helping me with this.
Ben,
Thanks again for the relation assistance, I have provided an example below of you're work.
For rectangular tubing:
IF HEIGHT == 7.00 & WIDTH == 4.00 & WALL_THICKNESS == .25
RAW_MAT_NUMBER = "910-020R"
ENDIF
For square tubing:
IF HEIGHT == 4.00 & WIDTH == 4.00 & WALL_THICKNESS == .25
RAW_MAT_NUMBER = "910-021R"
ENDIF
Jason
TomU
(To:jason.webb)
Jason,
If you need to check for lots of different conditions, you may find it easier to nest your statements. It's also a good idea to clear the parameter value. You don't want an incorrect value left if none of the cases are valid.
RAW_MAT_NUMBER = "
IF THICKNESS == 0.25
IF WIDTH == 4.00
IF HEIGHT == 4.00
ENDIF
IF HEIGHT == 7.00
ENDIF
ENDIF
ENDIF
