I cant figure out how to erase this line! Ive unmerged and merged several times and its still there.
Kaci
I think you have to blank that line, in case it's part of the table, and if it's not coming from the cell's content.
Select the whole table --> RMB --> select Line Display --> then in menu manager pick Blank --> and then select the line.
I'm sure you already checked, but it is not part of the annotation in the word material.
(i.e. Material_________ )
Thank you it worked! I just wish I can do the same thing when I'm editing the format file.
I just have to blank the line out everytime.
Kaci
Kaci,
my colleague uses Blank command in Format mode without any problem in any ProE/Creo release.
Martin Hanak
My selections in green and line display is greyed out.
You are welcome, Kaci.
You can save the table from the drawing into a tbl file, and then load this correct table into your format file.
Hey Jakub,
Do you know how to remove the borderline from the outside of the whole table? I used to be able to do this prior to Creo, but cannot find the pick now, if its still there.
Buddy Hudson
Hey Bryant,
I don't think it was ever possible to blank a border line of a table. Could you explain what would you like to have shown on your drawing?
