running trail files thru command lines ?
ejhlti
thru a command line, is there any way to run a trail file when proe is already running ? I know you can start proe via the command line, and specify a trail file to run, but I ws wondering if this can be done while proe is already running. Basically
Im trying to reduce eliminate the startup time. Is there any other trick to do this ?
> From: ejhlti@verizon.net
> wondering if this can be done while proe is already running. Basically Im trying to reduce
An asynchronous JLink or ProToolkit program can do this. I'm not aware
of any other utility.
Here is a minimalistic JLink example that toggles datum planes on/off:
System.loadLibrary ("pfcasyncmt");
AsyncConnection ac = pfcAsyncConnection.AsyncConnection_ConnectWS ( null, null, null, null, null );
currSession = ac.GetSession().RunMacro( "~ Activate `main_dlg_cur` `ProCmdEnvDtmDisp.ddisp` 0" );
If you used JLink, the best way would be to open a trail file and
execute RunMacro() on each line rather than hardcoding as above.
Unfortunately, the above consumed about 70MB RAM just to toggle
datum planes. JLink may be a little overkill for this problem.
There are several other (ProToolkit related) limitations as well.
Marc
