silhouette curve W3
rcrisp
silhouette curve W3
Proe Users,
How do you create a silhouette curve in W3. Stand on your head hold shift
while left clicking or something?
Ryan Crisp
Mechanical Engineer
501 Morrison Rd.
Columbus, OH 43230
P: (614)337-9979
F: (614)337-9499
www.prioritydesigns.com
First, you need a mold design extension, or similar. Maybe AAX. We use TDO (Tool Design Option)
Then, in part mode select Applications | Mold/Casting
Then select Insert | Silhouette Edge...
Christopher Gosnell
dgschaefer
(To:rcrisp)
Not true, it's integrated in the surface trim tool. You need a surface
copy first, then a plane for direction. That linked article sums it up,
although you don't need the datum plane they create in the first step,
at least in my experience. I think that was used more for placing the
rib than for creating the silhouette edge.
Doug Schaefer
LinkedIn
