Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Can you elaborate on your question some more? What kind of library do you want to set up? Creating and using mapkeys in Wildfire 2.0 is no different from previous versions. Unfortunately, it's difficlut to walk you through the whole process in the forum so I suggest you review the Help Center. It's a good start.
